Spot03547.pngCreating the room for a basic event
Command
Path
Create Room
Event Design
The first step of basic event design is usually creating the event room. Based on a simple 2D shape, the room and floor slab are created automatically according to specified parameters.
To create the room:
Create a closed 2D object (such as a rectangle, polyline, or polygon) to represent the room. The dimensions of the object should match the interior dimensions of the room to be created.
With the 2D object selected, select the command.
The Create Room dialog box opens. Specify the properties and attributes of the walls and the floor slab.
Parameter
Description
Walls
Specify the wall attributes
Height
Sets the wall height of the room’s walls
Class
To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the walls in the None class to set the attributes from the dialog box.
Thickness
Sets the wall thickness
Fill Hatch
Sets a fill hatch for the walls from the file’s resources
Fill Color
Sets the fill color for the walls
Pen Color
Sets the pen color for the walls
Texture
Opens the Resource Selector; double-click a resource to select it
Floor
Specify the floor slab attributes
Class
To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the floor in the None class to set the remaining attributes from the dialog box.
Fill Color
Sets the fill color for the floor
Pen Color
Sets the pen color for the floor
Texture
Wall and slab parameters can be edited in the Object Info palette; see Editing walls and Creating slabs.
When Moving connected walls with the Connected Walls mode of the Selection tool enabled, the adjoining walls and the slab change automatically to maintain the connection.
Editing walls
Creating floors
Creating a basic stage
Creating basic stage stairs
Creating a lectern
Creating a basic video screen
Creating seating sections
Creating basic event views
Setting class properties
Concept: Resource libraries
